1992 Factory Shop Manual Error Re: Idle Speed Control Check Procedure?
Family member reported that they could not restart 1992 Lexus ES-300. Manual 5-speed, so towed it home.
I discovered that flooring gas pedal allowed restarts, but if I let rpms drop below 3,000 engine stalled.
Read many posts to learn what others had found in correcting similar symptoms. On later Lexus engines,
this is generally described as the Idle Air Control Valve or IACV. According to the 1992 Factory Shop
Service Manual, the culprit part is called the Idle Speed Control or ISC, sometimes referenced as ISC valve.
Ok, for those who have not pulled any of these apart, I'll provide a short functional description.
You're familiar with "poppet valves" because one is used at your bathroom sink's bottom.
The 3VZ-FE engine uses a fancy poppet valve to control air flow into the intake system. They
control that valve's opening with a cute little electrical "stepper motor." Concentric with the
poppet valve's air-sealing end is a screw drive sort of like a screw-drive garage-door opener.
Rotate the screw one way and it opens the garage door or in this case opens the Idle Air Control Valve.
Rotate that same screw the other way to close. That rotatable shaft is rotated by a little 12 VDC 4-position
electrical stepper motor. Unlike conventional 12VDC motors, stepper motors only move by finite increments
with each new instruction. Since this motor has for positions and circles have 360 degrees, each new
instruction only rotates 90 degrees. This works out very nicely in allowing your engine's computer to
make little adjustments to how open that ISCV is at any time. Each pulse sent to the next electrical
terminal pair rotates the shaft 90 degrees which moves the poppet valve 1/4 of the distance the
worm gear shaft is cut. Rather elegant.
Now these things get really gooped-up (technical term) with lots of non-volatile gummy sticky stuff
that drops out of gasoline. Anyone who believes text-book explanations describing air only flowing
inward though induction tracks would expect that no gasoline would be flying around that far
upstream from the fuel injectors to cause any precipitation and gummy deposit build-up while driving
thousands of miles. But in reality, induction systems act more like organ pipes with air pulses
driving in and out differently with different rpms and throttle settings. Back when I was racing
motorcycles, we sometimes saw gasoline mist appearing in air several inches back from carb
intake horns. While Lexus engines use fuel injectors their intake tracks still cause fuel-laden air
pulses to fly forward and back within their induction tracks, which is exactly why all the way
back to your throttle plate, they become covered with gummy trash that drops out of fuel on its
pulsing journey into the combustion chambers. This isn't all bad because all that extra movement
helps evaporate liquid gasoline. Liquid gasoline can't burn. Only when it phase changes into gaseous
form can it burn. So the more that is in gaseous form when combustion starts the less will have
to phase change during the power stroke which reduces piston pressure "area under the curve"
that rotates the crank. Faster phase change from liquid to gaseous form improves fuel economy
and improves peak torque and improves peak horsepower. You want it. A price we pay to get
excellent phase change from this pulsing system is this gummy stuff we need to occasionally
remove.
That gummy stuff tries to stick throttle plates closed, but your foot and the steel cable easily
overcome its ability to stick those parts together. But that little Idle Air Control Valve seems
to fall prey to this sticky goop. One way to address that need to clean is to pay $417 for a new
one and labor to swap out the new for the old. While the mechanic is doing that, he / she could
with little more effort just clean your original valve so it is as clean as new. Would you throw
away one of your best dining dishes if you discovered that one had sticky cherry pie remains
hardened onto it? Most of us would not. A locked-shut ISCV is about the same situation. But
resist that urge to remove the deposits with your tongue. (silly humor)
Where is that little electric valve? Stand at the driver side of engine and follow the longest rubber
tube that extends from the 3 inch diameter rubber air tube between the throttle assembly and
the Air Mass Flow Sensor. That longest rubber tube connects to your Idle Speed Control Valve.
Make sure no children are around to hear your language when removing all those little hoses.
Removing them is the most taxing part of this procedure. One of those contains sweet-tasting
engine coolant which can poison your cat if they get a chance to drink it. So be prepared to
capture about a liter of coolant before the slow stream stops. Or you can anticipate that and
drain about 2 liters from your coolant system before disconnecting those tubes.
The black plastic housing secured by 3-too-easily-damaged philips screws has a 6-post electrical
connector. To remove that connector you must compress a spring-loaded latch which prevents
unintended disconnection. Since it has been attached for a while, it won't slide off without a little
struggle. Compress the latch tab and pull while wiggling. Don't just pull as that's much harder than
breaking it free with some wiggling. Just trying to keep this as easy as possible.
Two 12mm hex-head bolts secure the valve to the intake manifold. If the gasket which seals this
valve assembly to the intake manifold is damaged in any way, replace it. Ours appeared fine and
I cleaned the mating surfaces well before reinstallation, so I reused it saving a trip to the dealership.
Naturally the book suggests replacing it whether its good or bad. Why trust mechanic's judgement
calls? I might write the same advice were I writing for a Factory Shop Manual. If there's a chance
that it won't seal well, don't reuse it.
Now your ISCV is in hand. If you want to clean it rather than just replace it, you need to remove
those too-tight-to-easily-turn philips screws. I broke them free by simultaneously applying torque
with two tools. Mainly I used a 4 inch Vice Grip brand pliers set and a very tight-fitting philips screw
driver. Hints when trying to apply maximum force to philips screws. Select only the most tight-fitting
screw driver possible. If you feel even a few thousandth of an inch slop clearance, it's not tight
enough. Tap the screw driver handle end with a hammer. Not with destructive force, but sufficiently
hard to accomplish two goals. First goal is to firmly seat the screw driver into the screw's receiving
pocket. Second goal is to "disturb" the screw threads which reduces their break-away torque
threshold. This may sound silly, but it works. Work smarter not harder. When turning philips screws,
most of your force should be pushing the screw driver into the ramp-like philips screw pocket because
torque tends to push philips screw drivers out of their mating pockets. Terrible design. The rest of that
hand's force is used to turn the screw. With both locking pliers and good screw driver you'll be able to
break those screws free without ruining their philips pocket heads. That's an easily made error.
Now you are about to lift off the black plastic cap which contains electric stepper motor windings.
Some parts will become free to fall as you remove that cap, so don't do it while standing in
your grass. Over a table would be much better. What are these parts? First are 3 identical short
steel tubing spaces. They go inside the screw holes that hold the cap on so when you tighten the
screws you don't break the plastic. They absorb the load. Also you'll see 2 thin washers about
1/2" diameter. They are not the same. One is flat while the other is bent so it can apply spring
load against the rotor shaft end which prevents slop and adds just a little friction so vibration can't
rotate that shaft. I did NOT see which washer fit in first. But on reassembly I put the flat washer
next to the plastic housing and the spring washer right below it which complies with conventional
practice. Also you'll see 2 very nice sealed ball bearing sets that should spin freely.
I cleaned this with a starting fluid spray can. Brake cleaner spray would probably do as well.
DO not remove the white lubricant grease from the worm drive. It needs to turn freely. The spring
washer applies enough end load to prevent it from rotating with engine vibration. Recycling an old
tooth brush works well for this kind of cleaning.
Prop the throttle plate cable control bell-crank to the open position so you don't need to hold that
open during cleaning. I used a plastic screw driver handle to secure the bell-crank open. Now use
spray cleaner like starting fluid or brake cleaner to dissolve the goop as far inside your induction
track as you can reach with rag wrapped on a thin stick. That tooth brush helps with this. My
companion was astonished that this clean-appearing Lexus has so much black nasty goop anywhere
as what came out of that induction track. Old socks with heal holes make excellent rags. Nice if
they are white so you can better determine if you are still removing goop.
I was about to reinstall this assembly when I decided to run the Factory Shop Manual electrical
test procedure on it. It says to test by simultaneously applying +12 VDC to the center pair of 6
electrical connections. One small alligator clip easily spans both. The other 4 connections are all
negatives, numbered COUNTER CLOCKWISE starting from Top Right as S-1, S-2, S-3, and S-4.
Factory Shop Manual says test closing by touching ground to these terminals in this repeating
sequence: 1, 2, 3, 4 and repeat. Sure enough, the poppet valve closed by many little steps.
Then it suggests testing opening by cycling through this repeating sequence: 4, 3, 3, 1, 4 and repeat.
No, I'm not making that up. Not only is it NOT the reverse order of the correct closing sequence, but
it doesn't even include position 2!! Very suspicious. I tested it using that procedure. It failed to close.
Yes it jumps back and forth by tiny increments, but it will NOT close.
Now in frustration, concerned that I might need to either replace that absurdly-priced valve
or rewind its tiny stepper motor winding if it had a short or open winding, I went on line. AutoZone
also shows this valve and they include Densco's test procedure. Closing sequence is the same as
the Factory Shop Manual, which tested good. But their opening sequence is: 3, 2, 1, 4 and repeat.
Why they don't just list it as 4, 3, 2, 1, I don't know. Maybe Japanese logic? But by repeating both
become the same sequence. I ran that Densco test procedure and the valve tested good!!
I reinstalled it and the engine now idles like new.
Be patient when you first restart and do install with the valve fully open rather than closed. The engine
computer will keep tweaking at that position one increment at a time until it restores normal idling speed.
In our case, it took about 10 minutes by which time the engine was full warmed. Top up with antifreeze.
If you're a person who would throw away a $417 dinning plate just to avoid washing it, by all means,
feel free to throw away your gooped up stuck Idle Speed Control Valve.
I know this was long and rambling and included more information than most posts. But if I had had
this to read before I would have had a less frustrating experience. Cost for R & R at dealer for this
problem is way north of $500. Some have reported as much as $800. Just our local 7% sales tax on
that would be another $56. Lots of choices. Hope this helps other 3VZ-FE engine owners which includes
1992 & 1993 Lexus ES-300 and 3.0 V-6 Camrys for the same years.
John
  • 3 years later...
  • 2 months later...
