scottelble Posted May 3, 2008 Posted May 3, 2008 I was told by a friend that his es300 has an access door that allows the fuel pump to be changed without dropping down the gas tank...I am wondering if a gs 300 has the same?
mikegarth Posted May 3, 2008 Posted May 3, 2008 What Year is your GS300?? I have a 1993 and if you remove the rear seat you can access the fuel pump because the gas tank is in the trunk and there is an access door behind the seat.
scottelble Posted May 3, 2008 Author Posted May 3, 2008 What Year is your GS300?? I have a 1993 and if you remove the rear seat you can access the fuel pump because the gas tank is in the trunk and there is an access door behind the seat. It's a 98'
