Programming Seat Memory Buttons
dajig7
I needed instructions on programming the seat memory buttons on my newly acquired 2002 ES 300. Any help will be appreciated.
Hi
Your key has to be in the ignition and turn to the key the engine doesn't have to be running, gears have to be in park and the break engaged.
Setup you seat and mirrors the way you want and then press the set button and the seat 1 button at the same time and you will hear a beep
for seat 2 you do the same except press set and seat 2 at the same time till you hear the beep.
that's it
