dougeefresh Posted January 31, 2008 Share Posted January 31, 2008 Hello. I was driving yesterday and the temp gauge rose very close to the top of the gauge. I was on my way home so I just drove home. This morning, I decided to drive to work (about 6 miles) and when I was about 2 miles away from home, the needle was pegged at the very top of the gauge so I drove back home. Yes, stupid me... When I got home I could see the radiator fluid dripping on to the garage floor and white smoke from the engine bay (just a little). The reservoir was empty. My initial guess is that one of the hoses gave out. So my questions are: 1. How much damage could I have done and how can I find out if I had blown a head gasket/warped head? 2. What is the basic procedure to diagnose the problem before taking it to a mechanic? It's 92 ES300 with 156K and when I bought it 1.5 years ago, I did a flush and never had any problem with overheating. Thanks! Quote Link to comment Share on other sites More sharing options...
homemechanic Posted February 1, 2008 Share Posted February 1, 2008 It's a coolant leak.. . .don't think you really did any damages to your engine. check your engine oil. . no coolant mixed w/the oil = no problem Look for the leak. If you can't find it, tell us the approximately location. . .etc. .front or back of the engine. . .etc.. . The smoke is from burning the coolant. Possible leaks: water pump hoses radiator Quote Link to comment Share on other sites More sharing options...
byf43 Posted February 1, 2008 Share Posted February 1, 2008 Hello.I was driving yesterday and the temp gauge rose very close to the top of the gauge. I was on my way home so I just drove home. This morning, I decided to drive to work (about 6 miles) and when I was about 2 miles away from home, the needle was pegged at the very top of the gauge so I drove back home. Yes, stupid me... When I got home I could see the radiator fluid dripping on to the garage floor and white smoke from the engine bay (just a little). The reservoir was empty. My initial guess is that one of the hoses gave out. So my questions are: 1. How much damage could I have done and how can I find out if I had blown a head gasket/warped head? 2. What is the basic procedure to diagnose the problem before taking it to a mechanic? It's 92 ES300 with 156K and when I bought it 1.5 years ago, I did a flush and never had any problem with overheating. Thanks! This sounds like either the thermostat has stuck closed, the radiator has split (been there - done that!) or, as you say, a hose may have split. You MAY have had a head gasket rupture and the coolant went into the crankcase. (Let's hope that this did NOT happen!) Look closely at the radiator (with a flashlight) to see if coolant is coming out of the middle of it. As homemechanic said, check the oil to see the condition. If it looks like a foamy milkshake, you have problems. If the oil looks normal, you should be o.k. Check the condition of the hoses for leaks/splits. Quote Link to comment Share on other sites More sharing options...
dougeefresh Posted February 1, 2008 Author Share Posted February 1, 2008 Thanks, guys. I am gonna check it out and report back. Quote Link to comment Share on other sites More sharing options...
