Drivers Door
mrnaasty
If I understand the question correctly, turning your key in the lock won't unlock the driver's door and your key's remote entry button won't unlock any door. Did both these problems start around the same time?
Your key's remote entry button may not be working despite the new battery because the Remote switch on the dash got inadvertently set to OFF.
My stepson's 1994 ES300 cannot be opened at the driver's door with the key (he only has a valet key). He has to unlock the passenger door, then reach over the passenger seat from the inside and open the driver's door manually and then get out and walk around to the driver's door to get into it.
Is this the same problem you are having? If so, does this clarify the problem for anyone out there that might chime in with a solution?
thanks!
