baseball Posted January 6, 2008 Share Posted January 6, 2008 2001 es300 I just changed the timing belt on my car, I am now getting error code 1351 and code 1351 pd. Is the error code caused by the timing belt? Quote Link to comment Share on other sites More sharing options...
baseball Posted January 6, 2008 Author Share Posted January 6, 2008 I need to fix this issue with the check engine light asap, it is failing the CA smog test, because of three sensor failures. The car is running great, I have all of the codes............any ideas????? Quote Link to comment Share on other sites More sharing options...
powerwave Posted January 6, 2008 Share Posted January 6, 2008 vvt sensor code bank 2 sounds like one of the cams is off a tooth. redo timing belt lining up cams properly. Quote Link to comment Share on other sites More sharing options...
baseball Posted January 6, 2008 Author Share Posted January 6, 2008 vvt sensor code bank 2sounds like one of the cams is off a tooth. redo timing belt lining up cams properly. thanks, thats what i thought just wanted to get some confirmation. Quote Link to comment Share on other sites More sharing options...
