jttegx Posted January 4, 2008 Share Posted January 4, 2008 i installed HIDs in a 93' es300 and i was able to figure out the vertical adjustments of the head beams but how do i go about the left/right? i see a dial with teeth and a turning switch...i tried moving that using a 8mm socket wrench turning left and right but nothings moving. how do i adjust the left/right feature of the head beam? Quote Link to comment Share on other sites More sharing options...
Lexucan Posted January 4, 2008 Share Posted January 4, 2008 The dial you described is the one for the horizontal movement (left/right). You may not have turned it enough to see any movement of the headlight beam, it's very gradual. I'm curious, what HIDs did you install? Quote Link to comment Share on other sites More sharing options...
jttegx Posted January 4, 2008 Author Share Posted January 4, 2008 i need to make it fixed so its aiming more toward the left hand side of the road. would i want to dial it clockwise or counter-clockwise? i put in DDM hids 4500k Quote Link to comment Share on other sites More sharing options...
jttegx Posted January 7, 2008 Author Share Posted January 7, 2008 The dial you described is the one for the horizontal movement (left/right). You may not have turned it enough to see any movement of the headlight beam, it's very gradual. I'm curious, what HIDs did you install? i tried adjusting this using a 8mm socket at the end. its only moving up/down Quote Link to comment Share on other sites More sharing options...
