Program Key / Remote Locks On 92 Model ?
pete1rayce
I know this info is here somewhere, as I have done it and seen it before, but I am not finding it. Anyone care to direct me to the posting for the sequence of hoops I need to jump to re program my key to unlock the dorrs again.
It was working until I removed the radio today........
PS....The standard instructions ( below ) found all over the place do not work on a 1992 Model ES300, BUT last December / January, Someone here on this forum sent me the correct ones...I can't find that post.
HELP!!
These instructions, while great for those to whom they apply, do not work for my car.
Sit in the driver's seat and lock all the doors.
Unlock and open the driver's door.
Insert the key into the ignition and remove it (don't turn it...just remove it).
Using the MANUAL lock switch on the driver's door, lock and unlock the door 5 times.
Close the door.
Open the door.
Lock and unlock the driver's door 5 times (I'm almost certain you use the MANUAL lock switch again, but if this sequence fails to work, try again with the power switch).
Insert the key into the ignition and turn it to the "ON" position.
Remove the key.
The driver's door will now lock and unlock itself one time.
Press and hold the "LOCK" button on the key fob for at least 1 second.
Close the driver's door.
Open the driver's door.
Press and hold the "LOCK" button on the key fob for at least one second.
Press and hold the "LOCK" button on the key fob. The door will lock.
Press and hold the "LOCK" button on the key fob again. The door will unlock.
You should be all set.
