Abs Brakes
deerhunter
I have a 1995 ES300. About a month ago, the ABS light came on. I took it to the dealer and
they said the the right front sensor was bad. They wanted $550 to replace it. I found an aftermarket sensor for $89. I had a mechanic replace it, but he said that the original was really tight in the mounting hole and the replacement went in really easy. Should the replacement have fit tight in the hole? Since replacing the sensor, the light is off, but now just before the car comes to a stop the ABS engages. It does this sometimes when going straight, but almost everytime when the wheels are turned.
