Kevin Peterson Posted October 1, 2007 Share Posted October 1, 2007 the above problem happens at different times with no pattern. I suspected a fuel leak but when smell happens I checked underneath car and saw no leakage - there maybe seepage though - the smell when it happens is only inside cabin not outside Quote Link to comment Share on other sites More sharing options...
SVT tech Posted December 18, 2008 Share Posted December 18, 2008 the above problem happens at different times with no pattern. I suspected a fuel leak but when smell happens I checked underneath car and saw no leakage - there maybe seepage though - the smell when it happens is only inside cabin not outside I'm getting ready to work a 2000 ES 300 with same exact problem. Also CEL and Trac off lights are on. I haven't scanned yet, so I don't have the codes. I'm thinking evap purge soleniod for the smell, but I'm a Ford tech not a Lexy technician. Any common problems associated with these systems? Thanks in advance!! Quote Link to comment Share on other sites More sharing options...
SVT tech Posted December 19, 2008 Share Posted December 19, 2008 the above problem happens at different times with no pattern. I suspected a fuel leak but when smell happens I checked underneath car and saw no leakage - there maybe seepage though - the smell when it happens is only inside cabin not outside I'm getting ready to work a 2000 ES 300 with same exact problem. Also CEL and Trac off lights are on. I haven't scanned yet, so I don't have the codes. I'm thinking evap purge soleniod for the smell, but I'm a Ford tech not a Lexy technician. Any common problems associated with these systems? Thanks in advance!! I went and checked out the car tonight in person. I'm thinking it's the bank 1 position 1 oxygen sensor. The codes point me that way. That really makes more sense anyway. The car is probably running very rich due to the bad 02 sensor. Quote Link to comment Share on other sites More sharing options...
