Disassembly And Cleaning Of Lenses For A 96 Lexus Es300
mystic33
How does one disassemble the lamp assembly on a 96 ES300 in order to clean the internal lenses? Mine have a very frosty look to them and even changing the original bulbs to Sylvania Silverstars does not give me a much brighter beam. Is there a forum for this task or anywhere else that explicitly describes the dissassembly of the front shields, lenses, and bulb assenbly?
Thanks in advance,
mystic33
  • 3 weeks later...
Don't even bother taking them apart. if you have patients and time. Go buy Brasso. You can get it at any walmart home dept etc. Its a general purpose brass cleaner. BUT I had the same issue as you, and I was on the verge of purchesing new headlights. I used the brasso gave it two good rub applications on seperate days. let it set up. Wiped it off. And waxed them.
The lights look like new,
Ill post pictures later. Im currently at work.
