tjc73 Posted September 8, 2007 Share Posted September 8, 2007 Hey everyone, First off, thanks for all the great info. I've already removed my door panel and replaced the plastic door lock clip thanks to all the great advice here. Now I have a new problem. My gas hood supports on my '97 ES300 don't hold the hood up anymore and I need to replace them. I bought two new ones on ebay (not official Lexus or Toyota) and now I need to remove the old ones. Upon inspection, the top mount is a ball type mount with NO clips of any kind. I read on another post to apply sharp outward pressure and this should pop off the top portion of the support. I tried this with all my might and it didn't budge (and I tried removing it straight out and from several different angles- nothing worked). I then tried hitting it with a hammer close to the mount and this didn't help. I tried removing the bottom of the hood support and swiveling the base in order to pry the support off the ball mount and this didn't help (I may have even bent the hood slightly where the ball connector screws into the metal). I'm fairly convinced that I have to remove the ball mounts from the hood itself and replace the old supports with new ones that come with a ball mount already attached. I'm just wondering if anyone has successfully removed the hood supports from the ball mounts without having to replace the ball mounts themselves? The replacement hood supports I already bought didn't come with ball mounts so I'll have to buy new hood supports which will be a royal pain. Any advice would be much appreciated. Thanks, TJ Quote Link to comment Share on other sites More sharing options...
felixcat Posted September 11, 2007 Share Posted September 11, 2007 TJ, I have mine changed before. My Lexus mechanic told me that the top mount of the hood support is designed to be irremovable (or very very hard to pop off) once it is popped in, so the only safe way to remove the whole support is unscrewing the ball mount from the hood. Quote Link to comment Share on other sites More sharing options...
tjc73 Posted September 11, 2007 Author Share Posted September 11, 2007 TJ, I have mine changed before. My Lexus mechanic told me that the top mount of the hood support is designed to be irremovable (or very very hard to pop off) once it is popped in, so the only safe way to remove the whole support is unscrewing the ball mount from the hood. Thanks for the response. I figured that was the case, but I was hoping there was a way to get the ball mount out of the old hood support. Next, I'll see if they sell replacement ball mounts, and if not, I'm off to the Lexus dealership to buy official Lexus hood supports that come with the ball mounts installed (I don't even want to think about how much they'll charge!). Quote Link to comment Share on other sites More sharing options...
tjc73 Posted September 21, 2007 Author Share Posted September 21, 2007 After some effort, I found a way to remove the ball mounts from the old hood supports without causing any damage. First, you remove the old supports from the car. Next, you drill a hole in the support to the side of the ball mount using a titanium bit (see attachment). I used a 1/8" bit and it worked fine. At this point, you should see the ring that holds the ball mount in place (note: the attached picture was taken after the ring and ball mount were removed- it just gives you an idea of where to drill the hole). Using needle nose pliers, grip the ring and pull it out (you may have to twist it a bit to get it out). After that, the ball mount pops right out and you can install the new supports with no problem. The whole process probably took about 1/2 hour for both supports. Hope this helps. -TJ Quote Link to comment Share on other sites More sharing options...
