hrly68 Posted August 25, 2007 Share Posted August 25, 2007 I was interested in changing the fuel filter and I cannot seem to find it inline . I was wondering if someone can tell me where I can find the filter on my 91 es250 and please tell me if it is hard to replace ? thanks alot ! Quote Link to comment Share on other sites More sharing options...
powerwave Posted August 25, 2007 Share Posted August 25, 2007 those were intended to be lifetime filters, so unless you got bad gas or something you don't HAVE to change it unless you just feel like doing so. here's a shot of it (you may notice some things are missing from the engine compartment ), it's the small black cylinder with the nut on top in front of the brake cylinder. behind the LH headlight, behind where that motor mount would go. it's so-so in terms of ease, depends if you're handy, if you're used to pulling cars apart. ;) here's a shot of the engine compartment intact. mostly. good luck! Quote Link to comment Share on other sites More sharing options...
hrly68 Posted August 26, 2007 Author Share Posted August 26, 2007 oh my ! well thanks a lot for the heads up ! I did not know any of that . looks like I will use a good cleaner and get a tune up . thanks again for the good info ! those were intended to be lifetime filters, so unless you got bad gas or something you don't HAVE to change it unless you just feel like doing so. here's a shot of it (you may notice some things are missing from the engine compartment ), it's the small black cylinder with the nut on top in front of the brake cylinder. behind the LH headlight, behind where that motor mount would go. it's so-so in terms of ease, depends if you're handy, if you're used to pulling cars apart. ;) here's a shot of the engine compartment intact. mostly. good luck! Quote Link to comment Share on other sites More sharing options...
