yeer Posted August 21, 2007 Share Posted August 21, 2007 Hi, I recently bought a lexus es300 with 153,000 miles. I have the check engine light coming up, i check it and got the code:=== Primary Error Code === Error Code: P0773 Description : TCM Shift Solenoid 'E' (SL) Circuit Malfunction Possible Causes: * SL control circuit is open or shorted to ground * SL control circuit is shorted to system power (B+) * SL is damaged or has failed (an electrical fault) * PCM has failed Does any body know what the problem could be? Also , when I bought the car, the passenger side mirror housing had a peice missing on the corner, I wanted to get that replaced, does any body kno where i could purchase that? BTW When I change gears, I feel like a kick if i really press the pedal down, I dunno if thats normal or not.. any help appreciated. Thanks Quote Link to comment Share on other sites More sharing options...
