94 Es 300 Amplifier Problem
Dank3
Ive got a 94 es 300 aniversary edition w 140 000mi. Recently the front passengers side door speaker and the speaker above the glove box started crackling when the base hit. I thought it was a blown speaker but when the engine is turned off and the car is running on battery power it is 95% better. This makes me think it may be an amp problem. Any advice on this would be greatly appreciated. Also does any one know if these amps can be tuned?
Sounds like you might have a ground issue... could be in the amp, could be somewhere in the wiring. It definitely sounds like alternator 'noise' getting into your system. You should be able to find a replacement amp through eBay... or you can have mine. I don't know if it works or not, for it was disconnected when I installed the new stereo, but it's out of a '95... and you're welcome to it.
