Oil Maintenence Required Warning
I just got the oil changed at Jiffy Lube. The warning still says oil maintanence required. I pressed the odo button but the screen didn't go blank like it said in the manual. I tried to restart the engine with the reset buutton presseed for 7 sec. This didn't work either.
Thanks
gs300 Ken
  • 4 weeks later...
Thats the second step to the process...The first step is to go into INFO the go to SERVICE then reset the oil filter and oil change settings to zero so it starts counting the 5000 miles again.
After you do that you should hold the button for a couple seconds then start the car.
Lemme know if that works.
  • 3 years later...
Here is what I did to reset the Oil Maintenance Required light on my 06 GS 300. I turned the car off. I pressed the odometer button AND the reset button and held them down. I pushed the start button twice. It reset after about 2 seconds. Hope this helps.
