Gps Navigation
daikim99
Is there a way to by pass the "I Agree" Button on the navigation system for the GX470 2007 model. Everytime, I turn on the car, it ask me this question and I have to press "I Agree" to active the using of the GPS system. this is getting nuisance to press everytime the car is turn on. Is there a way to disable this question?
Thanks,
I installed the coastal lokpick and it was the best thing I have done to the 2007. It eliminates the I agree at start up and provides full functionality of the nav system and phone while moving. It is great.
My installation experience was somewhat longer than 30 minutes. It requires removing some of the trim to access the nav screen. Once there, it is a simple plug the lokpick in. Virtually foolproof and very easy. The slow part for me was the removing and reinstalling the necessary trim pieces. I went very slowly and deliberately as I didn't want to damage anything.
There is a thread where someone else explained the process in great detail.
As I recall, you start with the trim on each side of the shifter. After that is exposed, there is a screw at the bottom of the wood (actually plastic) trim on each side of the screen. Slowly remove those wood look trim pieces and then unscrew the bolts holding the video screen in place. Once that is pulled, the instructions are very precise on where to attach the harness.
I suggest testing it before reassembly. Be sure to read the intstructions for making the nav system work while in motion. You have to press an icon on a screen. After you press the icon it wil go through a series of screens and then you can use the nav system.
Good luck!
I installed the Lockpick 3. It eliminated the I agree and allowed nav and phone functionality while moving. I installed it last Fall, before coastal had the video on their site. The video is accurate, but I went very slow when removing the side (a/c) panels. The rest is easy.
I believe there was another version available when I purchased mine that also provided IPOD interface.
Hope this answers your questions.
