Obd2 Codes And Solutions
Hello,
I am ne to the forum. I have a 2001 ES300 with 145,000 miles.
It has been great except for two trouble lights that keep coming on.
They are Check Engine and Trac Off
When I use an OBD scan tool from Murray's, it says P0446 Evap Circuit Vent Malfunction
I can reset the codes and they will stay off for several weeks. I notice they come on when the tank is low and/or the temperature changes a bit.
Today I was going to reset them but the OBD said P0115 which was engine coolant temperature circuit malfunction.
Since I was having some very recent problems with low idle speed on cold start, I suspect this is telling the ECM that the coolant temperature is already hot and not to enrich the mixture.
I also realize this can be caused by the plugged throttle body air control valve.
My question is how do I find out what component to replace? Is the some temperature sensor somewhere that has failed.
Thanks for any guidance you can provide.
cdonpaul
Chelsea,MI
