adi Posted April 16, 2007 Share Posted April 16, 2007 Hi, I am considering a used sc 430 and wondering what will be a better buy: first option is a 115k miles for $21k with all maintainance records regulary performed (every 7,500 miles) second option a 60k miles for $26 k carfax does not show maintainance records I was wondering whicy is a better buy. Is mileage on the first car going to be a problem or contrary because of so many times beeing serviced is just like brand new//?? Also , both cars look and run beautifully. Any thoughts,??? thank you Quote Link to comment Share on other sites More sharing options...
Russ_B Posted April 17, 2007 Share Posted April 17, 2007 Hi, I am considering a used sc 430 and wondering what will be a better buy: first option is a 115k miles for $21k with all maintainance records regulary performed (every 7,500 miles) second option a 60k miles for $26 k carfax does not show maintainance records I was wondering whicy is a better buy. Is mileage on the first car going to be a problem or contrary because of so many times beeing serviced is just like brand new//?? Also , both cars look and run beautifully. Any thoughts,??? thank you Just some thoughts....Compare the year of the vehicles....the one with 60K you may be able to purchase an extended warranty whereas the 115K you will not ! The mileage is almost half ....you may consider having them checked out by a certified mechanic (make sure a compression test is done on all cylinders!) ~$75.00 of well spent money to run some diagnostics. I just purchased an '02 with 17,500. I plan on keeping it for a LONG while! Best of luck! Quote Link to comment Share on other sites More sharing options...
