Bubbles Posted August 24, 2003 Posted August 24, 2003 I've had this problem since test driving it at 127000 miles: At around 35 mph, I can hear this slow yet constant thumping noise as if something was wrong with the wheels. At higher speeds the thumping noise frequency is higher. I ended up rotating the wheels and the problem still persisted. I put my car up on jack stands and I wiggled the rear wheels and there isn't any wobbling so I dont' think it's the wheel bearings. Then I started the car up while on jack stands and I slowly got the car up to 35 -50 mph. I can definitely hear the noise from the back and it could be anywhere from the differential to the drive shaft to the brake system. Well I then turn off the car and I manually turn the wheel. I can feel a resistance on some parts when turning the wheel. If I turne the wheel fast enough I can hear some scrubbing noise. I changed the differential fluid with very thick 80w140 gear oil and I can still hear it and it's not any quieter. Any suggestions on where the sound is coming from?
JSC300 Posted August 25, 2003 Posted August 25, 2003 Its prob the Hub...or the bearings....i had that problem too...but i replaced the back hubs it was about 600 beans...but its fine now
