92'SC400 Posted January 22, 2007 Share Posted January 22, 2007 Lately i have been experiencing a shortage in power mostly at night when the lights are on, anything you touch that uses power dims the lights even when you hit the brakes. i checked the ground on the battery cable and it was a little loose so i tightened it up, it helped for a little while but the problem persists even though the cable is tight. Should i replace the ground that runs from the battery, and if i do is there another ground (ie. engine to frame). Also does the cable run to the starter and split of or something how is it ran i only briefly looked at it so can someone let me know please. Thank You in advance!! Quote Link to comment Share on other sites More sharing options...
