Interior Dome Light Out
douglasmiami
Recently (I'm having a bad month with my car) my interior dome light has gone out (door-triggered light on interior roof of car behind driver right shoulder). Is this a bulb or a fuse issue? Ib bulb, can I open dome light to replace?
Thanks.
Doug
Changing the bulb is easy just pry open the plastic cover with a screw driver. (tape screw driver head
so you won't scar the plastic) then change the bulb with the same new bulb . I doubt it's fuse issue, if it's
a fuse issue it's not only your dome light that will not function, but any way just to be sure double check your
dome fuse if it's busted or not.(refer to your manual-look for your FUSE BOX location)
