gizmofanv Posted December 22, 2006 Share Posted December 22, 2006 I would like to thank you in advance for your help! I have 98 ES300. Everything works fine except on and off no audio from the right side of the speakers. If I turn balance to right and cranck up the volume it picks up sound but goes off after sometime. What could be the problem and what need to be done? I called local Lexus dealer but did not want to diagnose over the phone. Thanks! Quote Link to comment Share on other sites More sharing options...
1995_ES300 Posted December 27, 2006 Share Posted December 27, 2006 sounds like a problem with the amp. Since it is getting a signal from the unit (occasional sound), it seems that it has problems outputting that signal from the amp to the speakers. Quote Link to comment Share on other sites More sharing options...
gizmofanv Posted December 28, 2006 Author Share Posted December 28, 2006 sounds like a problem with the amp. Since it is getting a signal from the unit (occasional sound), it seems that it has problems outputting that signal from the amp to the speakers. Thanks for your reply! That is what I thought but is it loose connection of the wiring or something within the amp is causing the problem? Any idea? Quote Link to comment Share on other sites More sharing options...
