lexus082 Posted November 21, 2006 Share Posted November 21, 2006 My solenoid wasn't unlocking the fuel door and the little metal rod would not retract unless you used the manual lever to open the fuel door. Then once I was done filling up on gas I would have to reach into the trunk and push the metal rod back through to lock the fuel door. Anyway, I knew the solenoid was still good so I thought I would take it out and see if I could possibly fix it. Sure enough after moving that metal rod back and forth a few times it started becoming loose from the solenoid housing and moved freely. Then I applied liquid graphite to the metal rod and it worked like new. Now I can unlock the fuel door by pulling up on the electronic lever by the front seat. I guess it was just dirty and the metal rod was seized up which required alot of force to move it back and forth. Saved over $200 for a new one so I am happy? Very easy fix. Quote Link to comment Share on other sites More sharing options...
