SuperCoupe400 Posted September 20, 2006 Share Posted September 20, 2006 Ever since I did my alternator & p.s. pump replacement (had to disconnect batt for those 8 1/2 hours) my steering wheels automatic tilt/telescope feature has stopped working like it used to. It used to be that it would initiate as soon as I put the key in the ignition. And if I turned the ignition before it was done tilting/telescoping it would pause, then finish the tilt/tele after the car was started. But now if I start the car before it's done with the tilt/tele cycle it just stops and doesn't continue the cycle after the cars started. So then I've got to hit my seat position preset button to bring it down the rest of the way. What in the world happened here? Seems like something probably got reset or cleared during that 8 1/2 hours my battery was disconnected. But I don't know what to do to get this tilt/tele back to normal operation. Any clues? Thanks Quote Link to comment Share on other sites More sharing options...
SuperCoupe400 Posted September 27, 2006 Author Share Posted September 27, 2006 So nobody's had this happen before? Guess I'll have to consult the dealer. :( Quote Link to comment Share on other sites More sharing options...
lexus082 Posted September 28, 2006 Share Posted September 28, 2006 Have you tried disconnecting the battery again to try to reset it, maybe even pulling the fuse for the components of the memory seat position system. Doesn't sound like its a problem with the motor or anything mechanical. Quote Link to comment Share on other sites More sharing options...
SuperCoupe400 Posted September 28, 2006 Author Share Posted September 28, 2006 Well, oddly enough, it just started working again on yesterday. Seems that everythings back to normal - without going back to disconnect the batt a second time. thanks anyway though, 082. Quote Link to comment Share on other sites More sharing options...
lexus082 Posted September 29, 2006 Share Posted September 29, 2006 Sometimes mine will be working fine and then usually when I adjust the wheel to come out further and then to go back in it just stops half way like it ran out of juice. Then if I try again later it will work fine. Its kind of strange I guess maybe the age of the motor or maybe it needs to be lubricated? Quote Link to comment Share on other sites More sharing options...
