weazel8 Posted May 13, 2006 Posted May 13, 2006 I just recenlty bought a 1991 LS400 with 189,000 miles. I bought it knowing the the A/C didn't work. I was going to recharge it. I checked it out and it hadn't been converted yet. So i went about converting it and when I did the pressure check there was no pressure so I assumed that there was no R-12 in it. So I began to inject the R-134 in it when I realized I didn't have a good seal and my pressure was good, but I had already injected a small amount of R-134 in to the system. So my quesiton is this. Is it bad if there is a small amount of R-134 mixed in with the R-12? Also no that I have done that my AC light flashes. I cant read any of the codes because my LCD is blacked out. Any ideas on what the problem for the no A/c would be as well
weazel8 Posted May 21, 2006 Author Posted May 21, 2006 I just recenlty bought a 1991 LS400 with 189,000 miles. I bought it knowing the the A/C didn't work. I was going to recharge it. I checked it out and it hadn't been converted yet. So i went about converting it and when I did the pressure check there was no pressure so I assumed that there was no R-12 in it. So I began to inject the R-134 in it when I realized I didn't have a good seal and my pressure was good, but I had already injected a small amount of R-134 in to the system. So my quesiton is this. Is it bad if there is a small amount of R-134 mixed in with the R-12? Also no that I have done that my AC light flashes. I cant read any of the codes because my LCD is blacked out. Any ideas on what the problem for the no A/c would be as well Bump
