hokiefan Posted March 26, 2006 Share Posted March 26, 2006 New to the forum, but I've been searching and haven't found an answer to my problem yet....any help is appreciated. Originally, the 6-disc trunk changer in my 96 es300 went out. I bought a replacement off of ebay and the one that came in did not work and worse yet, shorted out my head unit. I cracked open the head unit on the recommendation of Pioneersubuy and fixed replaced the 6.3A fuses on the circuit board and that fixed the problem for a while....then it blew the fuses again. I kept replacing the fuses each time this happened (4 times) until one day, when trying to repair, I noticed I had used a higher rated fuse by mistake....I know, ooops. Anyway, now I have bought another Headunit on ebay and tried plugging it in, but all I get is a green illuminated screen.....no LCD display.....no radio function. At this point, I would be happy to just get my radio function back (I can live without CDs). The replacement head unit I bought off of ebay is out of a 95es300.....I've been reading that some radios need codes to unlock, but I'm not sure how I would tell if a code would be needed to unlock it....and I'm not sure if I had the code, how I would enter it for the radio to acknowledge it? Bottom line is I have no radio function now.....although I do have two radios (one which I got off of ebay and was assured works and another with an excess power input problem which has bypassed the 2 6.3A fuses). I even tried to replace the back end of my old 96 radio with the back end of the 95 model purchased off of ebay.....no luck.....same result as when I just plugged in the ebay model the first time.....illuminated screen.....no digits or radio function. Can anyone help? Thanks. Quote Link to comment Share on other sites More sharing options...
