Toneonly Posted October 27, 2005 Share Posted October 27, 2005 This is my first time here on this forum...Just bought 1991 ls400 1250 dollars...ohhh about 200k miles yea sort of a steal i've had to replace the alternator. Still runs low on power steering and most recently gives trac off with check engine light on. Never one with out the other. Any suggestions? Quote Link to comment Share on other sites More sharing options...
rahlo1 Posted October 28, 2005 Share Posted October 28, 2005 your power steering pump is leaking probably from your air control valve. the fluid leaks down onto your alternator and fries it. there is a pic in the gallery that shows a cover that you can make for your alt. to protect it. the trac and engine lights are probably your oxygen sensors but to make sure get the codes read. Quote Link to comment Share on other sites More sharing options...
prix Posted October 28, 2005 Share Posted October 28, 2005 I saw that pic awhile back ... can you ever envision a situation in which that plastic would melt? there's a lot of heat under the hood at times, especially in sunny climes. your power steering pump is leaking probably from your air control valve. the fluid leaks down onto your alternator and fries it. there is a pic in the gallery that shows a cover that you can make for your alt. to protect it. the trac and engine lights are probably your oxygen sensors but to make sure get the codes read. ← Quote Link to comment Share on other sites More sharing options...
