LexusRide Posted July 27, 2010 Share Posted July 27, 2010 Gentlemen, Car was hard to start and had a rough idle. The problem was carbon/dirt had fouled the ICV (Idle Control Valve). This valve's function is to provide path for air to bypass the butterfly assembly in the throttle body at idle; with out it functioning correctly the engine is starved for air. This is a common problem that can be remedied with a good cleaning process with carburetor cleaner. When white electrical coil is removed from the ICV, it exposes a small pencil sized metal stud. This stud needs to rotate 1/8 turn feely and then one more additional 1/8 turn with some spring resistance for a total of a 1/4 turn. If this stud does not rotation freely, then the ICV will need to be cleaned. 08/092005 - No new gaskets were needed, used old ones with no problems. - Caution, when removing the ICV from the throttle body. Great care must be taken not to strip out the four screw heads when breaking the factory torque. A very tight fitting screw drive is essential. - DO NOT disassemble the ICV assembly after removing it from the throttle body; it has critical settings that may not be able to be maintained if reassembled. More pictures... http://www.thefilehut.com/userfiles/fnorman/DSC08219a.jpg http://www.thefilehut.com/userfiles/fnorman/DSC08220a.jpg http://www.thefilehut.com/userfiles/fnorman/DSC08221a.jpg http://www.thefilehut.com/userfiles/fnorman/DSC08222a.jpg http://www.thefilehut.com/userfiles/fnorman/DSC08223a.jpg http://www.thefilehut.com/userfiles/fnorman/DSC08226a.jpg http://www.thefilehut.com/userfiles/fnorman/DSC08227a.jpg http://www.thefilehut.com/userfiles/fnorman/DSC08228a.jpg http://www.thefilehut.com/userfiles/fnorman/DSC08229a.jpg http://www.thefilehut.com/userfiles/fnorman/DSC08230a.jpg http://www.thefilehut.com/userfiles/fnorman/DSC08233a.jpg http://www.thefilehut.com/userfiles/fnorman/DSC08234a.jpg http://www.thefilehut.com/userfiles/fnorman/DSC08236a.jpg http://www.thefilehut.com/userfiles/fnorman/DSC08237a.jpg http://www.thefilehut.com/userfiles/fnorman/DSC08238a.jpg http://www.thefilehut.com/userfiles/fnorman/DSC08239a.jpg http://www.thefilehut.com/userfiles/fnorman/DSC08240a.jpg fnorman HI, I tried to do this job with your help..... However, I couldn't see any pictures at all. Is there anyway you can post these pics again? I know that this was posted awhile ago. Thank you for your help, I appreciate it. Quote Link to comment Share on other sites More sharing options...
2CHP Posted December 4, 2011 Share Posted December 4, 2011 Please re-up the pictures to this old but great post! Quote Link to comment Share on other sites More sharing options...
Bio4x4 Posted March 17, 2012 Share Posted March 17, 2012 Please re-up the pictures to this old but great post! Going to do this today on my 95 ES300 and will post some photos about my progress. Quote Link to comment Share on other sites More sharing options...
