lex4me Posted June 4, 2005 Share Posted June 4, 2005 My 91 LS400 wipers are getting worse and worse at cleaning the upper portion of the windshield during a swipe - the wipers never contact the glass. I have replaced the wipers with two different brands to no avail. I am thinking that the spring on the arm has gotten weak. Has anyone been able to find a replacement spring, done something to tighten up the spring, or done anything other than go to Lexus to get a new arm? None of the after-market houses seem to carry the replacement arm and Lexus wants a small fortune. Please advise. Ed - using RainX for now. Quote Link to comment Share on other sites More sharing options...
Reyi Posted June 6, 2005 Share Posted June 6, 2005 This probably isn't your problem, but if it is, you'll be thankful because the fix is free. I have a 94LS400 and also use RainX wipers (they rule, huh?). Anyway, I recently noticed the top of the windshield wasn't being wiped and also that when the left wiper got to the bottom of its stroke (over the the right-bottom-center of the windshield) it would sort of skip and not wipe there either. Well, I stared at the wiper while it worked for a while and noticed that the bottom of the blade also seemed to be wiping lower than normal. That made me realize that it wasn't sitting as high up on the arm as it should be (or at least I hoped that was the problem). Well, that WAS the problem. All I had to do was basically yank up on the wiper and make sure it was all the way pulled up on the wiper arm. SHAZZAM!!! Good as new. Like I said, it sounds like your problem might be different, but I hope it's not. Quote Link to comment Share on other sites More sharing options...
lex4me Posted June 10, 2005 Author Share Posted June 10, 2005 Interesting observation. I did notice that the passenger side wiper was not fully engaged in the wiper arm and was able to pull it out further and lock it in place. The driver side wasn't fully engaged either, but no amount of pulling on it would engage it as the housing remains in the way. Perhaps the folks at rain-x didn't engineer their blade holder properly? Quote Link to comment Share on other sites More sharing options...
