Kowalski Posted May 21, 2005 Share Posted May 21, 2005 Alright, my check engine light came on and gave me a code P0770 shift lock solenoid. The car has been driving weird too...seems kinda weak but shifts feel like butter or just fine. I called lexus and the service manager said that the solenoid was located in the transmission and that usually if they replace the solenoid they have to replace the valve body as well. Now, I know a thing or two about cars and it makes no sense to me why the valve body should have to be replaced along with the solenoid. It just seems assinine and like this guy thinks that I am some dumbass who doesnt know a valve body from the hole in my butt. I want to know if you all have had any experience with this or something similar. He told me that the entire job would be $1200 before tax, worst case (valve body and solenoid). what sould I do??? Quote Link to comment Share on other sites More sharing options...
VGR Posted May 21, 2005 Share Posted May 21, 2005 The valve body just needs to be removed (not replaced) to gain access to all the shift control solenoids. Since the Lexus ES transmission is identical to the Toyota Camry V6 engine, you could take the car to a Toyota dealer and save several hundred dollars total in parts and labor. Quote Link to comment Share on other sites More sharing options...
gndmks12 Posted August 16, 2009 Share Posted August 16, 2009 I have a 98 es300 and my check engine light came on yesterday. I took it to autozone and they told me I had error code p0770 shift solenoid e malfunction. I got the part from the lexus dealer and attempted to fix it my self. We got the pan off drained all the fluid took off the filter. We took out all the 17 or 18 bolts that we thought held the valve body in but we must have removed the face plate because we still can't get the solenoid out. I appears to be hitting on the casting. can someone help me with a step by step? I bought a Haynes manual but it doesn't have anything in it about the solenoid. Quote Link to comment Share on other sites More sharing options...
