Transit921 Posted February 16, 2005 Share Posted February 16, 2005 are all waterpumps the same, im gona buy one off ebay, what are good parts for ur car, lexus cam timing belt, what are the better spark plugs and wires to get , and will any new water pump and pcv valve work, maby i should post this in maintence part of the forums , Quote Link to comment Share on other sites More sharing options...
Transit921 Posted February 16, 2005 Author Share Posted February 16, 2005 just wanna know, if a 40 dollar waterpump is ok Quote Link to comment Share on other sites More sharing options...
ArmyofOne Posted February 16, 2005 Share Posted February 16, 2005 just wanna know, if a 40 dollar waterpump is ok ← Go here: http://www.discounttoyotaparts.com Get one for a 1990-1991 camry V6. Its about $55. and its $50 cheaper than one from lexus. NEVER go aftermarket with something like a waterpump...it takes too much time to remove/replace to use anything but OEM. Quote Link to comment Share on other sites More sharing options...
Transit921 Posted February 16, 2005 Author Share Posted February 16, 2005 awsome Quote Link to comment Share on other sites More sharing options...
ArmyofOne Posted February 16, 2005 Share Posted February 16, 2005 awsome ← as i said, do not use aftermarket parts when doing something as critical as a waterpump. its hard to get to, and if the aftermarket opne fails early, you are back using 5-6 hours of labor when you could have spent the extra $10 and got the OEM. there are alot of times when aftermarket will do, a water pump is NOT one of them. CV axles are. and a PCV valve can be had from autozone for $5-$10. around there. aftermarket is fine in this case. Quote Link to comment Share on other sites More sharing options...
vcv10guy Posted February 17, 2005 Share Posted February 17, 2005 I'd get the OEM spark plug wires only from the website Josh (ArmyofOne) provided or you can try www.lexus-parts.com. As for the spark plugs you may want to consider getting iridium spark plugs, which is supposed to last longer than platinum and provide overall better performance. There is some available on ebay and you can also purchase them from www.sparkplugs.com. Quote Link to comment Share on other sites More sharing options...
