94 Es300 Dome Light
kbigstew
  • 5 years later...
the dome light cover just pops right out.... you can use something like a flat head screwdriver as leverage
I wonder if this applies to the front dome light, which is next to the sunroof buttons. I can see clips on the rear one, but not on the front one. In the front dome light area, I can also see or make little between the plastic frame and the roof. Now should I remove the whole assembly with the plastic frame or just the light cover? Thank you.
