How To Change Rear Brake Pads...
I know how to change front brake pads.  I just wanted to know if you do anything different when changing the rear brake pads (such as emergency brake, etc.)?  I have a 1996 GS 300.  Thanks!
Your car has 4 wheel disc brakes, so if you can change the front, you can change the back. Its exactly the same procedure. You don't have to worry about the emergency brake.
Thanks, tbone!
