Window Regulator/motor
At the risk of double posting...I will stick to this forum as it seems most appropriate. I am trying to replace the window regulator (back left) in an 94 ES...I have the door panel off and the old regulator (along w/ the motor still attached) basically out....i can't seem to get the old regulator "off" or unmounted from the motor though....
does anyone know the steps to follow here? just to get the motor/regulator unhooked? much thanks.
  • 4 years later...
John,
I have the same car with the same window regulator problem. I see your post from 4 years ago with no answer. What did you end up doing?
