mmorin Posted October 19, 2004 Share Posted October 19, 2004 The only problem I have with my Lexus is that the front left speaker will go out when I hit a bump. If I turn the stereo off and then back on the speaker will be fully functional again until I hit another bump. Sometimes it will flicker on and off without the bumps. It couldn't be a loose connection because every time I turn it off and on again it starts to work. PLEASE HELP IF ANYONE HAS ANY SUGGESTIONS. Thanks! Quote Link to comment Share on other sites More sharing options...
1SICKLEX Posted October 19, 2004 Share Posted October 19, 2004 The only problem I have with my Lexus is that the front left speaker will go out when I hit a bump. If I turn the stereo off and then back on the speaker will be fully functional again until I hit another bump. Sometimes it will flicker on and off without the bumps. It couldn't be a loose connection because every time I turn it off and on again it starts to work.PLEASE HELP IF ANYONE HAS ANY SUGGESTIONS. Thanks! ← There is a short with the speaker (wire). It needs to be replaced. Hey your in Atlanta. Check out www.seloc.net as well for answers. Quote Link to comment Share on other sites More sharing options...
TurboGS300 Posted October 20, 2004 Share Posted October 20, 2004 The only problem I have with my Lexus is that the front left speaker will go out when I hit a bump. If I turn the stereo off and then back on the speaker will be fully functional again until I hit another bump. Sometimes it will flicker on and off without the bumps. It couldn't be a loose connection because every time I turn it off and on again it starts to work.PLEASE HELP IF ANYONE HAS ANY SUGGESTIONS. Thanks! ← There is a short with the speaker (wire). It needs to be replaced. Hey your in Atlanta. Check out www.seloc.net as well for answers. ← If it's all factory it may also be a blown speaker, however if anything has been changed in the door then it's probably the terminals or wires shorting out from some mickey mouse job someone did. B) Quote Link to comment Share on other sites More sharing options...
