jfranke Posted June 19, 2004 Share Posted June 19, 2004 I just finished replacing pads on all 4 wheels (spent total of maybe $70 on parts instead of $250 - 400 at dealer). After I bled the lines pretty thoroughly, but am getting a "ssssst" noise when I press brake pedal now. Seems to be coming from under the fluid reservoir under the hood...and honestly it sounds like air in the line...? The bleeders on each wheel stream without bubbles when bled, so not sure that more bleeding will solve the noise problem. Brakes work fine, it's just a noise problem at this point. But where there's noise, there's bound to be something un-right going on... thanks -jfranke. Quote Link to comment Share on other sites More sharing options...
