Help! I have lost an important item that slipped under the center console of my 2007 RX 350. I have tried everything. Can I remove the center console? I know that I can slide it back and forth, but I need to remove it.
Here are instructions I found from a member of another forum for removing the center console in an 04 RX330 -- I don't know if it is the same for your 07 RX350:
1. Move the seats all the way forward, slide the console all the way back
2. From the rear seat, you will see a plastic panel on each side of the sliding part of the console. It is 250mm long or so and roughly rectangular
3. Put a putty knife or something thin in and pop that out from each side
4. Now you can remove the 6 bolts. The forward most bolt is a little tough, you need to move the seat all the way forward.
5. Now you can lift the console enough to remove the wiring harnesses that are attached at the front of the console.
6. Remove the two screws from the front part, and now you can remove the whole thing.
  • 1 month later...
