lemon Posted July 13, 2009 Posted July 13, 2009 So you can educate your dealership when they tell you they can't duplicate your problem. I'm slowly downloading more of these as I get them, so keep checking back. 1. Air conditioning poor peformance - AC002_05.pdf 2. Air conditioning sensors inspection - AC005_04.pdf 3. Headlamp condensation - BO003_07.pdf 4. Front brake squeal - BR001_05.pdf 5. Brake acutator abnormal noise - BR003_07.pdf 6. Malfunction indicator lights after brake pad change - BR006_06.pdf 7. Retrieving diagnostic codes (unfortunately this is with the Lexus diagnostic equipment) - EG009_05.pdf 8. ISC learning procedure (this is a good one to be used after drained or disconnected battery) - EG010_05.pdf -this TSB mentions using the Lexus diagnostic equipment but look for my other post for directions for the ordinary mortal who doesn't have the Lexus scanner 9. Rocking feeling at 70mph - EG013_07.pdf 10. Power back door noise - EL013_07.pdf 11. Zero point calibration after wheel alignment - L_SB_0015_08.pdf 12. Tonneau cover latch rattle - NV001_07.pdf 13. Vehicle pull/drift to right improvement - ST003_05.pdf 14. Cylinder head cover oil baffle caution - L_SB_0021_08.pdf 15. Upper/Lower windshield tick noise - NV005_06.pdf 16. Instrument panel rattle - NV002_06.pdf 17. 5W20 oil recommendation - EG006_06.pdf 18. Front seat squeak noise - NV001_06.pdf 19. TPMS diagnostics etc. - PG001_07.pdf __________________________________________________________ The following are not TSBs, but good information to have. FRONT AND REAR BRAKE EXPLODED VIEW (from and RX330, but I believe RX400 is the same) front_brake_component.pdf rear_brake_component.pdf STEREO REMOVAL rx_stero_remove.pdf DEALER SELECTABLE OPTIONS (wish I knew why Lexus made it so only the dealer can adjust these) rx400h_customized_settings.pdf VOICE TEL and NAV COMMANDS (if you can get the stupid system to understand you) 2007_RX400h_Voice_Commands.pdf LexusVoiceNavwTel.pdf 2
Gryphon Posted July 15, 2009 Posted July 15, 2009 Very nice work, Lemon. Thanks for the great effort. Tom
duty222 Posted July 18, 2009 Posted July 18, 2009 This is so helpful. thanks for posting it. Now the service advisor in Lexus will know what I'm talking about if there an issue .
SOMEONE ELSE'S GOT MY NAME Posted April 23, 2010 Posted April 23, 2010 This is so helpful. thanks for posting it. Now the service advisor in Lexus will know what I'm talking about if there an issue . Yes ... THIS is helpfull ... Lexus shop is NOT helpfull. We're ready for our THIRD ... count 'em ... THIRD set of tires, in only 42,000 miles. (TSB relating to alignment pulls to right) No problem? TSB applies if you're under 50,000 miles. Yet according to Lexus our 400h has over 48 months FRIOM IN-SERVICE date. Lexus says that means once it was manufactured ... even if it wasn't bought/driven/registered for THREE months prior! I'm thinking, "eh! no big deal ... 6 months ago, we paid $2,000 for Lexus' extended bumper to bumper warranty (just in case these people tried to wiggle out of stuff like this). I wouldn't think we'd have to pull the extended warranty card. After all, we've been having to get it aligned & aligned & aligned again & again to no avail. WHY didn't these people run a TSB check?!? Why is it that the customer has to WAVE the TSB in their face?!? WHY won't they simply CHANGE OUT the G.D. part?!? (taking a deep breath). OK, so I'm going back down again, today, to see what the next run around will be. (sigh) Maybe I should take it to the Toyota shop in stead. They've always shown more integrity & character regarding repairs than any of our Lexus experiences. I'd certainly prefer to experience customer care, and integrity ... than a waiting room that serves foo-foo coffee. Meah - maybe that's just me.
dion Posted April 30, 2010 Posted April 30, 2010 So you can educate your dealership when they tell you they can't duplicate your problem. I'm slowly downloading more of these as I get them, so keep checking back. 1. Air conditioning poor peformance - AC002_05.pdf 2. Air conditioning sensors inspection - AC005_04.pdf 3. Headlamp condensation - BO003_07.pdf 4. Front brake squeal - BR001_05.pdf 5. Brake acutator abnormal noise - BR003_07.pdf 6. Malfunction indicator lights after brake pad change - BR006_06.pdf 7. Retrieving diagnostic codes (unfortunately this is with the Lexus diagnostic equipment) - EG009_05.pdf 8. ISC learning procedure (this is a good one to be used after drained or disconnected battery) - EG010_05.pdf -this TSB mentions using the Lexus diagnostic equipment but look for my other post for directions for the ordinary mortal who doesn't have the Lexus scanner 9. Rocking feeling at 70mph - EG013_07.pdf 10. Power back door noise - EL013_07.pdf 11. Zero point calibration after wheel alignment - L_SB_0015_08.pdf 12. Tonneau cover latch rattle - NV001_07.pdf 13. Vehicle pull/drift to right improvement - ST003_05.pdf 14. Cylinder head cover oil baffle caution - L_SB_0021_08.pdf 15. Upper/Lower windshield tick noise - NV005_06.pdf 16. Instrument panel rattle - NV002_06.pdf 17. 5W20 oil recommendation - EG006_06.pdf 18. Front seat squeak noise - NV001_06.pdf 19. TPMS diagnostics etc. - PG001_07.pdf __________________________________________________________ The following are not TSBs, but good information to have. FRONT AND REAR BRAKE EXPLODED VIEW (from and RX330, but I believe RX400 is the same) front_brake_component.pdf rear_brake_component.pdf STEREO REMOVAL rx_stero_remove.pdf DEALER SELECTABLE OPTIONS (wish I knew why Lexus made it so only the dealer can adjust these) rx400h_customized_settings.pdf VOICE TEL and NAV COMMANDS (if you can get the stupid system to understand you) 2007_RX400h_Voice_Commands.pdf LexusVoiceNavwTel.pdf
Jim Nazium Posted August 7, 2010 Posted August 7, 2010 This is so helpful. thanks for posting it. Now the service advisor in Lexus will know what I'm talking about if there an issue . Yes ... THIS is helpfull ... Lexus shop is NOT helpfull. We're ready for our THIRD ... count 'em ... THIRD set of tires, in only 42,000 miles. (TSB relating to alignment pulls to right) No problem? TSB applies if you're under 50,000 miles. Yet according to Lexus our 400h has over 48 months FRIOM IN-SERVICE date. Lexus says that means once it was manufactured ... even if it wasn't bought/driven/registered for THREE months prior! I'm thinking, "eh! no big deal ... 6 months ago, we paid $2,000 for Lexus' extended bumper to bumper warranty (just in case these people tried to wiggle out of stuff like this). I wouldn't think we'd have to pull the extended warranty card. After all, we've been having to get it aligned & aligned & aligned again & again to no avail. WHY didn't these people run a TSB check?!? Why is it that the customer has to WAVE the TSB in their face?!? WHY won't they simply CHANGE OUT the G.D. part?!? (taking a deep breath). OK, so I'm going back down again, today, to see what the next run around will be. (sigh) Maybe I should take it to the Toyota shop in stead. They've always shown more integrity & character regarding repairs than any of our Lexus experiences. I'd certainly prefer to experience customer care, and integrity ... than a waiting room that serves foo-foo coffee. Meah - maybe that's just me. No, it's not just you. Lexus has come a long way in engineering there vehicles, but unfortunately they are far off when it comes to training there grease monkeys. . I am sorry about the derogatory remark to all those mechanics who perform there work with pride and love, but the sad fact of the matter is that most of the grease monkeys, to them, it's just a job. And if Lexus wants to truely pursue perfection, they need a major in house cleanup and either fire or retrain Lexus dealers who cannot perform a repair or maintenance the first time round. Yes, mistakes and over sites occur, but EVERYTIME I am taking my vehicle in for something as simple as an oil change, the dealer always finds something to repair or replace (be it in or out of warranty) and fubar's it up. It is SOOOOOOOOOOOooooooooooooooooooo frustrating having to be the one (the owner) responsible for the dealers mistakes. Cheers, MadloR P.S. you'll remember my post about how the dealer fubared me with the windshield etc...
DSQUARED Posted February 17, 2011 Posted February 17, 2011 As of 02-2011, are there any recently released TSB's for the 2006 RX400h?
Arjuna Posted April 10, 2011 Posted April 10, 2011 Thanks for this. I got my Lexus as a hobby and this stuff will load the record books for reference
RaleighNCRX Posted April 22, 2011 Posted April 22, 2011 8. ISC learning procedure (this is a good one to be used after drained or disconnected battery) - EG010_05.pdf-this TSB mentions using the Lexus diagnostic equipment but look for my other post for directions for the ordinary mortal who doesn't have the Lexus scanner Hi Guys.... I tried to search for this other post with no luck. Can someone by chance point it out?
RaleighNCRX Posted April 22, 2011 Posted April 22, 2011 Nevermind... Found it! http://us.lexusownersclub.com/forums/index.php?showtopic=58930 Thanks for your post! The info is awesome...
Guest Posted November 1, 2011 Posted November 1, 2011 so for number .9 rocking feeling at 70mph I can go to the dealership and get that done if my rx400h is under 100k miles?
CalvinHenry Posted December 12, 2011 Posted December 12, 2011 As of 02-2011, are there any recently released TSB's for the 2006 RX400h? For instance, what do I do now that the very poorly made master key fell apart above a toilet & is now gone forever. Vehicle is locked in a carport. How do I go about getting into the locked car to retrieve the coded key in the instruction manual? Are there any key replacement services for a Lexus RX400h on-line, whose replacements will actually allow me to drive the car to the dealership? Or, how do I get in the car without setting off the alarm? The local locksmith is too scared to do it :|
jmoe2012 Posted November 8, 2020 Posted November 8, 2020 Awesome thread, Lemon! thanks for sharing all the TSBs! Two thumbs up, Sir!
care_mentor_288 Posted February 19 Posted February 19 Does anyone have any information on the front dashboard crumbling? I heard it was being replaced in the past.
HaloRomeo27 Posted February 24 Posted February 24 On 2/19/2024 at 12:10 AM, care_mentor_288 said: Does anyone have any information on the front dashboard crumbling? I heard it was being replaced in the past. That has expired and the only way to replace it now is purchase a new one honestly is not a hard job just takes a lot patience i replaced mine and several others
