Removing The Radio..
ben99lx470
Is the CD player broken or just jammed? If it is just jammed you can fix it yourself by using a plastic fork, spoon or fork handle to push it back in or use a pair of forceps to pull it out.
If you are still bent on taking it out, youll have to pry it out from the top, side and bottom of wood trim.
-Robert
I used the screwdriver head on my swiss army knife to pry it out. Try to do a search on google for removing the LX radio. I remember seeing some pictures somewhere.
Just try using a plastic fork handle to stick it in the slot to see if you can push the CD back. When you hear it moving around, it is trying to load/eject the disk but since it isn't where it's suppose to be, the mechanics get caught on the jammed CD.
How did this happen? Did you run over a bump and it stopped working?
-Robert
