Heated Seats
lexusboy
I checked the fuse - it is fine
The light on the buttons (both L and R side) both work
I checked all the harnesses - all are connected
The weird thing is that I dont even see where any wires would go into the seat to the heating element..
I think to remove the leather and get to the heater itsself you would have to remove the seat from the car?
Seems easy but definitely a couple of hours of work for a novice like me...
Ok here's a kicker....
www.newlexusparts.com (Park Place Lexus) - cannot find the heating element as a separate part.
You have to buy the leather, which has the heater built in -
$900+ for the seat bottom,
$1300+ for the seat back...
A used whole seat is ~$200 at www.parts.com so that may be the way to go unless you can find the heater as a separate part somewhere!
Hopefully this is not right - help!!
Ok my local dealer has the parts...
He will discount them since I bought the car there...
$340 (reg 395) for the seat bottom heating element
$220 (Reg 251) for the seat back.....
plus all the clips (~$1 each)
Labor would be at least $200 to $300 anywhere you go
So we are looking at around $800 to get it all working again (if you dont do it yourself)
there are places you can buy aftermarket seat heaters
try looking on google
for about 200 for a pair both front seats
an auto upolstry shop can remove the leather and replace for about 100-200 both seats at the most
it is actually real esy once to remove the seat from the car
all it is is hog pin clips basically a round peice of metal
about an hour to do a chair if you do it your self
only 4 bolts to pop out the chair
and the new ones should come with a new relay so all you neeed to use is the old wiring before the relay to hook up to the switch
