yomest Posted April 8, 2007 Share Posted April 8, 2007 hi guys, new to the club, hope you guys can help. i have a 92 LS 400, miles are 108,000, the check egine light stays on, i have ran the codes and they come up 25 and 71, 25 says car is running lean, 71 says EGR malfunction, i cleanded the EGR out and replaced the air filter, but still the codes keep coming back after i reset them, any suggestions? roy. Quote Link to comment Share on other sites More sharing options...
cardona6569 Posted April 8, 2007 Share Posted April 8, 2007 I think your problem also lies withing the electronics of the EGR as well as the Oxygen sensors may be due to be changed. I think you would need a pro to tackle the issues. CPR hi guys, new to the club, hope you guys can help. i have a 92 LS 400, miles are 108,000, the check egine light stays on, i have ran the codes and they come up 25 and 71, 25 says car is running lean, 71 says EGR malfunction, i cleanded the EGR out and replaced the air filter, but still the codes keep coming back after i reset them, any suggestions? roy. Quote Link to comment Share on other sites More sharing options...
LScott400 Posted April 8, 2007 Share Posted April 8, 2007 I would resolve the Code 71 first. This should help: EG602dtc71.pdf Quote Link to comment Share on other sites More sharing options...
yomest Posted April 8, 2007 Author Share Posted April 8, 2007 I would resolve the Code 71 first. This should help: EG602dtc71.pdf thanks guys, i will check out the electronics of the EGR valve first, plus change out the O2 sensors. any other suggestions, let them come. thanks again. you guys are great. Quote Link to comment Share on other sites More sharing options...
yomest Posted April 9, 2007 Author Share Posted April 9, 2007 I would resolve the Code 71 first. This should help: EG602dtc71.pdf hi, does anyone know where the ECU/ECM is located, fixed o2 sensor problem now have a code 31 VAF PROBLEM, 71 IS still coming up also. thanks guys Quote Link to comment Share on other sites More sharing options...
LScott400 Posted April 10, 2007 Share Posted April 10, 2007 hi, does anyone know where the ECU/ECM is located? EG416ecm.pdf now have a code 31 VAF PROBLEM EG578dtc31.pdf Quote Link to comment Share on other sites More sharing options...
