Key Program
can anyone help me program the key with the built in remote to my 98 gs400? i contacted lexus(usa)but they said that i have to send the car back over(usa) & i'm in the bahamas & thats to expensive for me, & we don't have a lexus dealer in the bahamas
wireless.
1- all doors closed and locked except drivers door (open and unlocked)
2- place key in ignition turn it to on and off
3- cycle the manual door lock from unlock to lock 5 times
4- closed the driver side door and open the driver side door
5- perform step 3.
6- place key in ignition and turn it on to off (one time to add a key) on and off two times ( rewrite ) pull key out of ignition, the door lock should response by going to lock and unlock( one time to add key) lock and unlock two times for rewrite mode.
7- push lock and unlock bottom on key together for 1 sesond and push unlock one time.
if procedure is performed correctly the door lock will lock then unlockand alarm beper will sound.
immobilizer.
1- start car and stop car. remove key from ignition cylinder.
2- place registered master key in ignition do not turn on.
3- push gas pedal 5 times
4- push brake pedal 6 times
5- take out registered master key from ignition.
6- place new key in ignition. do not turn on
7- push gas pedal one time.
8- wait 60 seconds, the factory security indicator should go off then the key is programmed.
the immobilizer section will only work if you have a registered "Master key" if you only have a valet then it will not work unless the valet was registered to be a master key.
its sounds kinda crazy to send a car back to the states just to get the keys programmed. :lol:
wireless.
5- perform step 3.
immobilizer.
Here you go. :cheers:
key_program_gs.pdf
  • 2 years later...
  • 1 month later...
I've got a similar problem on my 1995 GS300, I unhooked the drivers side door "indicator" so i could have the door open and it wouldnt beep while listening to music. Key got in washamashine(thanks to wife) and the dealership said it would be 477.00 to replace a door latch? i have the new key from the dealership, they said they just can't program it cause of the latch being disabled????, can i just take the latch sensor off another door and then program it?, becausethe remote locks & unlocks fine without the latch "sensor" on the driver side door ,you just need that to "program a new key".
Any ideas very appreciated!!! :P
PEACE!!!
  • 1 year later...
  • 6 months later...
My second key is acting weird. Its him I cannot program for keyless. Everytime the car sits at home within the range of the second key, it opens all windows. So I thought to reprogram it, but it didnt work. The red light also flashes for no reason.
I fixed it by taking the battery out of the second key.
I have tried every option there is in the interenet about programming.
We'll see how it goes.
  • 10 years later...
Hello I bought my new car at auction (03 Lexus GS 430) and I only have ONE key(don't know if it is a master key or not) when I enter the key in the ignition, the security light doesn't go off and when I turn on start,the car crank but won't start. Also the remote doesn't work. Can anyone please help me start my car ??
On 11/14/2010 at 10:33 AM, denis_demenis said:
take a look here it can halp you HTTP://DEMENIS.AMAZINGWEBMALL.COM
Hello I bought my car at auction (03 Lexus GS 430)and I only have ONE key ( don't know if it is a master key or not) when I enter the key in the ignition, the security light doesn't go off and when I turn on start,the car crank but won't start. The remote doesn't work.Can you please help me start my car??
