deadmilenko Posted December 20, 2005 Share Posted December 20, 2005 When I turn my fan on floor, 85% of the air flow comes out the defrost vent and the 15% out the floor. When it is turn on floor and defrost it is the same result. Maybe it has always been like this. But this is the first time I have noticed it. Has anyone else experienced this problem? Quote Link to comment Share on other sites More sharing options...
GuyTelefunken Posted December 20, 2005 Share Posted December 20, 2005 I'm guessing an airmix door/motor/position sensor problem. Check for codes. Climate_Control_Codes.pdf Quote Link to comment Share on other sites More sharing options...
deadmilenko Posted December 20, 2005 Author Share Posted December 20, 2005 (edited) thanks Guy, I will check it out and post the results. Edited December 21, 2005 by deadmilenko Quote Link to comment Share on other sites More sharing options...
deadmilenko Posted December 21, 2005 Author Share Posted December 21, 2005 Here is the results but I only get a two diget code. Do I just disreguard the B1421/ in front of the 21? I think that these are my codes? Quote Link to comment Share on other sites More sharing options...
GuyTelefunken Posted December 21, 2005 Share Posted December 21, 2005 (edited) Read note number 3 under the code descriptions. 21 and 24 are probably normal depending where you did the test. To look into this problem furthur will most likely require digging deep into the dash. There are other tests the Lexus dealer can do first. I would recommend giving the dealer a visit. Edited December 21, 2005 by GuyTelefunken Quote Link to comment Share on other sites More sharing options...
