All Activity
This stream auto-updates
  1. Today
  2. Yesterday
  3. Last week
  4. They have been made by Aisin for decades and Japanese producers do not switch suppliers easily at all. Long term relationships are how they run their businesses. I would assume they made them for those too.
  5. Let me refine and simplify my issue. Anything not listed below works fine. -Key remote will pop trunk. It only beeps if I push the Lock button but not Unlock. Won’t unlock/lock doors. -Power locks don’t work with or without key remote. Locks only work manually. -Window switch only works after I lock/unlock the door, then works fine. Master switch only controls drivers window -Horn doesn’t work - fuse is good and I can hear the horn relay clicking when horn is pressed, so that rules out bad switch or clockspring. -Dome light doesn’t work on “door” setting, but works when switched to “on” position. -Drivers side seatbelt height adjuster doesn’t work, passenger side does -Side mirror adjuster doesn’t adjust either mirror -Power folding mirrors don’t work, mirror vibrator works -Seat/steering wheel memories won’t program or work - all seat and steering wheel adjusters do work. All fuses are good. Haven’t checked every relay though. No CEL or Airbag lights.
  6. I’m trying to find out who the original manufacturer was for the timing belt in a 1992 sc400. Does anyone know by chance
  7. Now wait a minute. I have owned an FJ80, an LX450 both were FULL TIME 4WD which means unless you Stop/neutral , shift your transfer case into “4lo” you , by default in 4hi the rest of the time, NO? What you DO NOT want to do is drive on pavement with the Center Diff. locked- very bad. If we all take a look at our GX470’s transfer case shift lever you will see it says “H/N/L therefore if you’re not crawling as long in 4low your only choice is 4hi. Not trying to be a Weisehiemer. I just assumed we all knew what we are driving.
  8. Anyone know the purpose for this blank panel?
  9. My dash indicates on my rear door is open on my Lexis GX470, but I keep closing the door but it keeps indicating my rear door is open.
  10. 200 LX470 OEM remote finally died. Purchased aftermarket and had it programmed by a local locksmith. My issue is distance for the remote to operate…it will only function within 10” of the front windshield. I have tested and replaced the remote battery three times. Could this be the range of the aftermarket remote or something within the vehicle (receiver)?
  11. Well I have the supplies but have not performed the change yet. I have had the battery disconnected a couple times and that seemed to help for a while - no idea why. Checking with Lexus the transmission has the latest software.
  12. I own a 2000 RX 300 first my parking brake light remains on even though the parking brake is not on, next the windows including the sun roof would roll down when I touched the driver's window button or when I turned the ignition key to off position. Now the engine light comes on and off and there is a different sound coming from the engine. Overwhelmed with all I took the vehicle to a Toyota dealership near me and was told that I have sludge and the engine needs to be replace. I not sure what to do. Please give some advise.
  13. @srgilbert I too am experiencing some 3-2 and 2-1 downshift harshness on a 2014. I’m curious if you were able to get the fluid exchanged, what method you ended up using, and if it resolved your issue.
  14. Looking for a transfer case for my 2004 GX470
  15. Trust me, I’ve searched and watched almost every YouTube video I can find. my car is a imported 1997(1998) Celsior with only 42,000 miles and bone stock. Runs/drives great. here’s the full list of what’s not working horn, door dome light, power folding mirrors/mirror adjusters(mirror vibrator works), remote key, saved seat/steering wheel memories, master window switch/lock(drivers window works)[all window switches work at each door], don’t think my bumper cornering blinker lights turn on with blinkers(bulbs are good), drivers side seat belt height switch, and I think I found out today my cruise control doesn’t work. Checked EVERY fuse in engine bay and kick panel, all good and clean. Dome light turns on manually but won’t with doors. Every light works except possibly my cornering lights. All other systems work perfectly. Touch screen is fine, radio works, function buttons on steering wheel works, all electric seat buttons work, steering wheels telescope/height, etc. no dash codes or check lights on. many people have one or two of these issues independently but not all together, and their fixes are usually fuses or high mileage wear and tear. The key remote has newer batter and will beep but not unlock the doors. i have unplugged the battery a number of times but none of the typical system resets seem to work in my situation. I have a hard time believing all these systems are connected to one problem but my friend i got the car from drove it from the port in Cali all the way up the coast to WA and said EVERYTHING worked perfectly before it sat for a number of months.
  16. I recently changed my gear shift box on my 1996 lexus ls400, after changing it i’ve had a few issues. first my speakers all went out except for the back right side door. secondly the car starts great and acts normal, but after a few minutes shuts off completely. driving feels normal then the car just shuts off, the lights stay on but the engine shuts if completely. sometimes before turning off the check engine light flashes on and off, as well as the “trac off” light. additionally while in park the speedometer starts moving up and down before the engine cuts off. i have no idea would it could be, if anyone has any ideas it would be much appreciated!
  17. Hi there, Got some videos on YouTube, but found someone in Atlanta that can help me with changing the compressor. Thanks for the suggestions.
  18. More fun! After replacing the oil pressure sensor I did not have the low oil light pop up, however I also did not do the O/D off and on to see if it would trigger. Going to try that again this weekend. However more codes showed up! Current list: P0125 - Several reports say this is related to the O2 sensors. I am going to check all the wiring and make sure they're plugged in and then possibly replace the O2 sensors if that does not fix it. P1130 - Rear bank air fuel / O2 sensor needs to be replaced... hmm this is interesting... P1133 - Upstream O2 sensor is bad... well another O2 sensor, wonder if they used non-denso parts. Going to clean the MAF and see if it helps. P1153 - Yet another O2 / Air fuel sensor. This is interesting! Definitely going to check for vacuum leaks as well as the current O2 sensors. P1351 - I have gone through roughly 3 different sensors, one OEM Denso from a junkyard, one NGK, and one generic from Amazon. I think the engine may be slightly out of time and it's due for a timing belt replacement so that may fix the issue.
  19. Hello Planenut25. My contact email is stiches2003@gmail.com I can do Venmo or a check in the mail is fine. Once I receive this I will get right on mailing this to you and you can put it to good work. Contact me at the above email and I can give you the Venmo contact or my personal address to send the check to. Charles
  20. If this is still available, how do I purchase it from you?
  1. Load more activity
