95 Es300 - Change Rear Tail Light Bulb?
Hi, i'm new here but I've read some of the posts. Anyway, my wife's 95 ES300 has one of the rear brake lights out. I was going to change it but when I took a look to replace the bulb, I couldn't see any sockets. Do you have to remove the whole tail light assembly just to replace a bulb? Also what size nuts are used (8mm, 10mm?). Any help is greatly appreciated.
no, no removal is necessary.
you just have to pop a couple of the fasteners that secure the trunk liner and the bulb sockets will be exposed. (new fasteners are available at Lexus if you break any)
Search on this as lexusk8 has posted pictures and given good instructions as to the steps involved.
steviej
Stevie, the '95 is a little different from the '97+...we have a stupid trunk with the extra narrow opening. You do have to remove the whole freakin light. It's a real pain in the !Removed!...I did it when I put the gold package on my ES(the emblem was embedded in the light, so I just bought a used one on ebay). Once you pull back the lining in the trunk, you'll see a metal plate where the screws(that hold the taillight assembly in) are...I'm about 99% sure that there is no way to do it while the light is in place. Sure enough, my burnt taillight icon came up the other day, so I'm going to be doing this procedure too...arrr.
:cheers:
yeah those lights are sealed up real well... My 96... i have to do mine ... my taillight dash thing came on too . !
bad design.. those narrow trunk... dont know what they were thinkin :chairshot:
you basically remove all little stupid carpet thingys in the trunk that are covering the tail light.
take out a few 10mm nuts.
(on passenger side, you need to remove 1 or 2 nuts for locking mechanism.
your taillight should easily be removed from the car. replace light bulb.
it took me about 10 minutes my first time. my second time..2-3 minutes.
Thanks for all your help. I eneded up buying an 8mm deep socket to remove the 6 nuts (5 or 6 - can't remember) and slide the light out far enough to remove and replace the bulb. There are some bigger nuts (10mm) that don't need to be removed to slide the light out. It would be harder to remove the 8mm nuts without a deep socket but I guess it can be done. Anyway, thanks for the great input and helping me change the bulb. Never thought I would need to search the web just to replace a light bulb. This was for the drivers side rear lights.
  • 4 months later...
Anybody have a list of lightbulbs that you would need to purchase if you wanted to replace every bulb in the taillight assembly for a 94 ES?
Also, I've seen some LED lights that you can purchase for brake lights, etc... I put some into another car that I owned as was not impressed with the brightness. Anybody seen anything different that they would recommend?
Both of my license plate lights are burned out so I will be pulling both of my taillights in the next week and replacing all of my bulbs at once while I am there...
you mean like this list:
1994 LEXUS ES300
Low beam headlamp
9006
9006ST Silverstar High Performance Halogen Upgrade: The Look of HID: Whitest, Brightest
9006XV XtraVision Halogen Upgrade: Up to 20% Brighter
9006CB Cool Blue Halogen Upgrade: White Hot; Super Cool; 100% Street Legal
9006LL Long Life Halogen Upgrade: Lasts one and a half times longer
High beam headlamp
9005
9005ST Silverstar High Performance Halogen Upgrade: The Look of HID: Whitest, Brightest
9005CB Cool Blue Halogen Upgrade: White Hot; Super Cool; 100% Street Legal
Parking light
1157A
1157AST Silverstar Signal Lighting: Complete the Look: Crisp, Clean, Style
1157ALL Long Life Upgrade: Up to twice the life of the standard lamp
Front turn signal
1157A
Rear turn signal
1156
1156LL Long Life Upgrade: Up to twice the life of the standard lamp
Tail light
1157
1157LL Long Life Upgrade: Up to twice the life of the standard lamp
Stop light
1157
High mount stop light
921
921LL Long Life Upgrade: Up to twice the life of the standard lamp
Fog/Driving light
H3-55W
H3ST Silverstar High Performance Halogen Upgrade: The Look of HID: Whitest, Brightest
License plate
168
Back up light
1156
Front sidemarker
1157A
Rear sidemarker
168
Glove box
74
Dome light
DE3175
Step/Courtesy light
161
194
194LL Long Life Upgrade: Up to twice the life of the standard lamp
DE3021
Trunk/Cargo area
194
Instrument-general
194
here is your link to the bulb list
steviej
So if I wanted to replace every light bulb in the rear taillights of my 94 ES 300:
I count 3 brake lights per side (6 total 1157’s),
two corner markers (lights up with my parking lights-does not light up with my brakes) (2x 168),
two reverse lights (2x 1156)
two turn signals (2x 1156)
and two license plate lights (2x 168)
Does anyone see anything that I missed (that may be burned out bilaterally)?
OK, i replaced all of my taillights tonight! Thanks stevieJ for the parts list! Since I do not appear to be the only one with ??? on how to do this, I took pics and placed a thread in the tutorial section for future reference:
http://us.lexusownersclub.com/forums/index...showtopic=15005
Its a piece of cake once you do it, took me about an hour but I was taking pics and notes...can be done much quicker.
