JERr Posted July 10, 2022 Posted July 10, 2022 My 2006RX 330 vibrates when it it put into gear. When put into park, neutral or with acceleration it goes away. I had the front and front passenger side motor mounts replaced. The other mounts I was told are ok. Also told the catalytic converters are bad. Dont know if that could be related. Plugs and coils were replaced. Otherwise the car runs really well.
RX400h Posted July 10, 2022 Posted July 10, 2022 Perhaps if the catalytic converter is partially plugged and producing excessive back pressure, the idle will drop. This could be the problem. A test would be to disconnect the catalytic converter and then see if the vibration goes away.
