sgriffith Posted May 19, 2004 Share Posted May 19, 2004 In my 99 RX300, the front driver & passenger seat belts are getting loose. There isn't much tension on them anymore from the area that pulls them back in when they are not in use (don't know the technical name for that part ;-) ) Is there some procedure that I can do to bring that tension back or am I looking at replacing those things if I want them to work like new again? Anyone out there done this before? Thanks in advance for all of the advice.... --Skip Griffith Quote Link to comment Share on other sites More sharing options...
sealevel Posted May 19, 2004 Share Posted May 19, 2004 same car....same problem... Quote Link to comment Share on other sites More sharing options...
Rollingstone Posted May 19, 2004 Share Posted May 19, 2004 The seat belt retracting problem is common. Surprisingly the solution is simple. If your vehicle is still on warranty advise your dealer of Technical Service Bulletin 'BO009-01' SHOULDER BELT ANCHOR TAPE SET. My dealer wanted $35 for essentally two small pieces of tape. The problem is caused by accumulated dirt and lint on the shoulder belt anchor where the belt goes over your shoulder and turns a sharp angle to go down into the door post and into the retractor. I used a small knife to clean out the dirt - the kit provided by Lexus has a piece of velcro-like matereal to scour away the accummulation. My seat belt now retracts like it's supposed to and the repair cost nothing. Go Flames! Quote Link to comment Share on other sites More sharing options...
sgriffith Posted May 19, 2004 Author Share Posted May 19, 2004 As I read your post I thought to myself...surely not....it can't be this simple of a problem....well...it is. I just ran outside & did it ....they work great now! Thanks a million for the reply. I can't believe that caused that much of a problem!!! Quote Link to comment Share on other sites More sharing options...
G and C Johnstone Posted February 3, 2005 Share Posted February 3, 2005 There you have it. On my old Lexus there is a key hole at either end of the slot in the shoulder anchor point. So easy to feed a rag moistend with a multi cleaner to clear away whatever was dragging on the belt slowing its retracting. I wonder how many good belts might have been discarded or swapted out by the money hungry service agents often talked about in L O C. Thank you Mr Rollingstone. Quote Link to comment Share on other sites More sharing options...
mikecolorama Posted February 4, 2005 Share Posted February 4, 2005 I was having this problem and thought that the tensioners were bad. Atleast that's what the dealer told me. They also told me that it would be about $530+/- to fix both the driver and passenger side. Thank you so much for the advise. I can't believe how good they work now just from cleaning them. Quote Link to comment Share on other sites More sharing options...
laivindil Posted February 5, 2005 Share Posted February 5, 2005 I just did this on my mom's RX300. We use a cleaner called "Simple Green" instead of a knife. Worked better and we didn't have to worry about nicking the seatbelt. Quote Link to comment Share on other sites More sharing options...
douglasmiami Posted February 28, 2005 Share Posted February 28, 2005 The seat belt retracting problem is common. Surprisingly the solution is simple. If your vehicle is still on warranty advise your dealer of Technical Service Bulletin 'BO009-01' SHOULDER BELT ANCHOR TAPE SET. My dealer wanted $35 for essentally two small pieces of tape. The problem is caused by accumulated dirt and lint on the shoulder belt anchor where the belt goes over your shoulder and turns a sharp angle to go down into the door post and into the retractor. I used a small knife to clean out the dirt - the kit provided by Lexus has a piece of velcro-like matereal to scour away the accummulation. My seat belt now retracts like it's supposed to and the repair cost nothing. Go Flames! ← Sorry guys - I must be the slow one here. But where is the problem? I'm sitting at work trying to think about how the seat belt is configured...is this dirty area easily accessible without removing any covers or other plastic? Quote Link to comment Share on other sites More sharing options...
melhadri Posted March 5, 2005 Share Posted March 5, 2005 I also cleaned it and now it works great. Look at the object that the seat belt runs up and down on. There is an accumulation of dirt where the seat belt and object intersect. Quote Link to comment Share on other sites More sharing options...
mago Posted March 5, 2005 Share Posted March 5, 2005 I also cleaned it and now it works great. Look at the object that the seat belt runs up and down on. There is an accumulation of dirt where the seat belt and object intersect. ← Lexus tried to fix my 2004 by using grease and it did not work. I have an appointment with them Monday to replace the retractable part. I was told that this is a known problem. Tom Quote Link to comment Share on other sites More sharing options...
