2015 RX350 Power Rear Door Close Button Not Working
2015 RX 350 power rear door button does not close the rear door, probably 4 out of 5 times. It beeps twice and nothing happens. Has anyone seen this before and any thoughts on a fix?
Thanks.
Go to 2:18 in this video: Note: I'm not sure this is your model but some of its features will be similar to yours.
  • 2 months later...
On 4/21/2022 at 9:39 AM, Matt P said:
Sorry - should have been more clear. The button on the rear door.
I've had luck doing this:  Open the door manually.  Close the door manually.  Press and hold the door button on the dash by the driver's side.   Most times it will beep and start working.  If it doesn't work, try it again.  There is a section in the owners manual about resetting it, in case a 2015 procedure is different than a 2010.
