Mirror Computer
My outside mirrors don't work but the fuses are fine and the little switch seems to read voltage changes so i think its ok.
I have read on another thread that a common problem is the mirror computer located somewhere in the dash.
http://us.lexusownersclub.com/forums/show....t/ST/f/4/t/2841
Does anyone know the part # and or where it is located in the car?
I am going to talk to the dealer but they are usually vauge on part #'s and prices are crazy.
Any help would be good.
Thanks in advance.
If you ask the dealer then they should be able to tell you the P/N and by the diagram of the EPC you should be able to see where it is located at. Id either get the wiring diagrams or a Haynes manual for repairing
AlsSC300 Writes:
"SliderMike -- have you had any luck getting/replacing the mirror
computer? I have a '93 SC300 with neither side mirror working -- and also
the seat position memory is not working.
AlsSC300"
AlsSC300:
Please read through the Visitors and New Club Forum for details on how to use the LexusownersClub.com.
Thanks a lot in advance.
UCF3
Moderator SC and LS Forums
